export to library error
I'm trying to edit an OD turning tool in NX9.0 from the tool library. After I edit the choices in the dialog box (insert shape, position and so on), I click export to library.  I get asked "Do you wish to replace it or create a new cutter?" I click create, i select my od_turning in the target class, and get the error "unable to update file".
Can anyone help with this, much appreciated.
Rolando
Re: export to library error
Do you have write permission to the folder where the library resides?
If you don't have your CAM customization placed in a separate structure to have it update save and writable, you should do so.
Read the "NX Custom" threads for your NX release about the best practice to customize NX.
Stefan
I have write permissions.
I'm not sure what you mean by CAM customization being placed in a seperate folder.  Can you help me out with this please.
Try it, and when you get the error, go to the NX log file (Menu -> Help -> Log file)
Go  to the bottom and search up to see if there is anything more specific (i.e. what file it was trying to write to)
@Rolando wrote:
Stefan
If you are nut using Teamcenter, then when you export a tool, it is modifying a file - tool_database.dat. If you modify the one from Siemens, you risk loosing your edits when you update the software. To get started, take a look at Getting started with NX CAM customization
Mark Rief
Retired Siemens
Mark,
I watched the NX customization video (very helpful).  I edited the ugii_env.dat file and created the resource, usertools and bitmap folders.  I launched NX from my shortcut and opened the log file.  the paths to the folders I created are not shown but all my CAM folders show the new path. Attached is the log file.
There is no log file - just a picture of part of it. Is the ugii_env.dat file in the "start in" folder of your shortcut?
If so, I would need to see the env and syslog text files - not pictures.
Mark Rief
Retired Siemens
Mark,
Yes, the ugii_env.dat file is in the "start in" folder.
attached are syslog text file and the .dat file
FYI, I have been able to create tools and export them to the metric file and see them in my tool_database.dat file.  But I am unable to do the same to the english file, hence the error to "export to library"
From the syslog, we see these are the folders the system is looking in:
    UGII_CAM_LIBRARY_DIR             C:\Users\surirol\Desktop\DESKTOPlibrary\
    UGII_CAM_LIBRARY_TOOL_DIR        C:\Users\surirol\Desktop\DESKTOPlibrary\tool\
    UGII_CAM_LIBRARY_TOOL_ASCII_DIR  C:\Users\surirol\Desktop\DESKTOPlibrary\tool\ascii\
    UGII_CAM_LIBRARY_TOOL_GENIUS_DIR C:\Users\surirol\Desktop\DESKTOPlibrary\tool\genius\
    UGII_CAM_LIBRARY_TOOL_INCLASS_DIR C:\Users\surirol\Desktop\DESKTOPlibrary\tool\inclass\
    UGII_CAM_LIBRARY_TOOL_ENGLISH_DIR C:\Users\surirol\Desktop\DESKTOPlibrary\tool\english\
    UGII_CAM_LIBRARY_TOOL_METRIC_DIR C:\Users\surirol\Desktop\DESKTOPlibrary\tool\metric\
The problem is the space in the file path to your ugii_env.dat file:
UGII_CAM_RESOURCE_DIR=C:\Users\surirol\Desktop\DESKTOP JUNK\cnc training\demo\resource\
The definition stopped at the space after DESKTOP. You need to either make a file path without spaces, or enclose the path in quotes.
Mark Rief
Retired Siemens
