expression feedrates
hello ,
i would like to put an expression in tab cut feed
unfortunately for me i can't , only a value is possible ! Smiley Sad
you have solution ?
thanks for the help.
11 REPLIES 11
Re: expression feedrates
You can do it in postprocessor. I have a same project for ABB water jet robot, and feed is a function of material thickness.
How you did it? External DLL?
nice !!
my siemens partner found me a solution :
"No formula is kept in menus machining operation. You can use a mathematical formula but it is evaluated and the result appears in the menu immediately.
for ouptut CLS solution is to use variables in your CN and type these formulas using UDE Insert"
IMHO :-)
I abhor the "INSERT" UDE
It gets you around the immediate problem, but is VERY non-portable (across machines/controllers/etc.).
If you know how & have the time, I'd come back and create a specific UDE for this (e.g. "Feedrate variables") then you could set a different variable for specific types of feedrates (e.g. engage/cut/retract/etc.)
ken ,
i agree with you but i don't have acess at Post processor ! just the CLS file
Cut = 200
engage = (cut * ( 50%)) : it's ok with nx !
cut_aera = (cut * (50%)) Smiley Sad
How about using feed rate optimization introduced with NX8?
This reduces the feed rate according to the amount of removed material.
thanks stefan , but i don't understand this method for 5 axes
What is "cut_aera"? I am not familiar with the term.
Are you trying to set NX motion types hased on the cut feed? This is there in NX8.
Mark Rief
Retired Siemens
Mark ,
"What is "cut_aera"? I am not familiar with the term."
"Are you trying to set NX motion types hased on the cut feed? This is there in NX8."
that is this function like stefan says ?
because i don't know how to use this function for 5 axes toolpath ??
