feeds and speeds library
Hi all,
The feeds and speeds libraries located on C:\Program Files\Siemens\NX 9.0\MACH\resource\library\feeds_speeds\ascii could they be linked with .CSV file insteaf of a .DAT file?
Could be changed somehow the .DAT file to excel format .CSV etc add and change data and convert this file to .DAT again?
Thanks.
Re: feeds and speeds library
There is an example CSV file included in that location, see sample_machining_data.csv
You can import the dat file into Excel and specify the pipe (|) as the separator.
After your changes export as tab separated text.
In a text editor replace all tabs by the pipe character to get the DAT format back.
