file type STL for model Stock
can I use a file type STL model Stock in NX 8 or 9?
if you can use an STL file which are the steps?
thank you very much!!!
Sorin Marcu
CNC Programmer
Matrite DACIA-Group Renault
Re: file type STL for model Stock
just change your selection type when picking bodies
Jake Hardwick
CNC Programmer
Senior Aerospace AMT
Production NX8.5.3.3 Beta testing NX10.0.1.4
I'm sorry, I did not make myself clear
I attached a picture may be clearer
thank you!
Sorin Marcu
CNC Programmer
I'm still not quite sure what you're asking for.  The picture I took was how to select a faceted body for your stock definition.  Are you asking how to put a STL into the manufacturing assembly?
Jake Hardwick
CNC Programmer
yes
want to define an STL as stock
and a STP as part
assemblies should probably do not know
thank you!
Sorin Marcu
CNC Programmer
Siemens Legend Siemens Legend
Siemens Legend
Hello Marcu,
Looking from a process point of view, i might ask you: Where is this STL file coming from?
In NX8 it is possible to use "IPW - In Process Workpiece" as a Blank Selection.
This allows you to select the "rest material" from a previous NX CAM Setup.
It does not matter if that is a setup in another part or the same part.
If your Blank (STL) is coming from another source than NX you need to open/import the STL file, add it to the assembly and follow the selection that CAM has given.
Gerrit Koelewijn
If you offer a stp file and STL file can I make a film for manufacturing assembly?
please more !!
Sorin Marcu
CNC Programmer
