holder check problem!
I get a lot of times holder collision error when create rest milling operation with holder check.
how can I solve like this problems?
I sent prt file and jpeg.
thanks.
NX 11.0.2.7 MP10 / Testing NX 12.0.2.9
CanikSoft NC Post-Processing & G-Code Simulation
www.plast-met.com.tr
www.caniksoft.com
Re: holder check problem!
isn't there any idea while check tool and holder bar option is choosen with check for ipw collisions,why tool holder is colliding part?
www.caniksoft.com
I have same problem again.I think Nx holder check option has some problem.
How I tell about this problem to GTAC,any help??
www.caniksoft.com
Go to http://siemens.com/gtac/ and select the option "create or update an incident report".
If you are unsure, ask your Siemens representative or your reseller, they should know Smiley Wink
This could be an issue with the tolerances, but I am not sure. By reducing the tolerance from .005 to .001, it went from 2 holder touches to 1. Increasing the holder clearance from .5 to 1 removes all collisions, but you should not have to do that.
For sure log a call with GTAC so thta deveopment can look in to it.
Mark Rief
Retired Siemens
thanks for your valuable replies.
I will call my reseller to do that.
www.caniksoft.com
