how to create toolpaths with taper holes
3 REPLIES 3
Re: how to create toolpaths with taper holes
I believe that the hole milling operation will only machine straight holes.
I attached a file of a recent project where I needed to machine a tapered hole. I roughed out with the hole milling operation then went to cavity milling and finished the hole with a Z level profile.
Kurt Neubaecker
CAD/CAM Designer
Proficient Industries
Cleveland, Ohio
Use STREAMLINE or CONTOUR AREA and you will have a conical spiral hole.
tuyệt vời!!!
thank you !
