how to define maximum range depth in shop documentation?
Re: how to define maximum range depth in shop documentation?
You will probably need to do this inthe post, since you really need the output Z coordinates.
There is a previous discussion and custom command in the archives:
http://community.plm.automation.siemens.com/t5/NX-CAM/max-and-min-z-depths/m-p/247022#M15917
Mark Rief
Retired Siemens
thank you very much for your suggestion and reply.
Access Denied...
You do not have sufficient privileges for this resource or its parent to perform this action.
How do i get sufficient privileges/ access to the archive?
/Rickard
@R_Sandin wrote:
Access Denied...
/Rickard
This area contains archived threads from the GTAC Support Forums, also known as the BBS. The content in this area is accessible by maintenance-only customers.
Mark Rief
Retired Siemens
Thank you.
