how to edit reuse components
Trying to add a Vise from Reuse libray and cannot adjust the jaw opening or step width
Mike
NX 11.0.2.7
Win 10
I noticed that in NX9, rapidly double clicking the value...
I noticed that in NX9, rapidly double clicking the value to edit does not work . If you pick once and hold the mouse button down a few seconds release and pick aging and hold the value should go into over strike mode. See the attached video...
Re: I noticed that in NX9, rapidly double clicking the value...
I found by accident that triple clicking seems to do the trick as well, then I was able to edit the field. I have noticed that on a couple of different programs over the years not sure if it is an operating system, mouse or program issue, thanks for your help
Mike
NX 11.0.2.7
Win 10
