cancel
how to make a turning program using curve
hi
i use nx 8 to make turning programs
my problem is that the tool path with machine cutter compensation or the real profile tool path is not same as the profile. between two curves or line and curve a sorter linear movement appears and the machine gives error
is it possible to use 2D curve of profile to generate the tool path or how can i overcome this problem
thanks and regards
irfan
When using curves for geometry and/or stock in turning, c...
Siemens Enthusiast Siemens Enthusiast
Siemens Enthusiast
When using curves for geometry and/or stock in turning, create a boundary from the centerline out to represent one half of the turned part.
Rob
