how to mill cone holes 5axis
in the attached file i want to machine the  yellow cone holes in 5 axis machining.
how?
nx10
Thank"s
Re: how to mill cone holes 5axis
Method with Variable Contour :
Drive Method > Surface Aera or Streamline
Tool Axis > Swarf Drive or Relative to Drive
Projection Vector > Tool axis or Toward Drive (if you have a taper Angle on the tool ,it is better)
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Hello ,
I've attached your model to a few created operations.
Hello
Thank you very much for your program.
it helped me a lot.
why did you build 2 cylinders?
can you machine the holes with variable contour?
 regards,
Amnon Smiley LOL
Siemens Legend Siemens Legend
Siemens Legend
Hi Amnon,
You can use use contour Profile with multiple depths, but only with zig pattern and NCM connections in between (not helical path ans you probably want here).
Yours
Eddy Finaro
NX CAM Product Manager
Siemens PLM
