import Gerber data
Solution Partner Innovator Solution Partner Innovator
Hi
Do you know the Gerber data?
I want import gerber data.
Is it possible?
File Name Extension is phd,phl,ptb.
Re: import Gerber data
What are the files - 2D CAD? Drawings? Nesting? cutting programs? electrical or mechanical?
If it is geometry, can you export something more neutral from the Gerber system, like dxf or iges?
Mark Rief
Retired Siemens
