''import machine kit'' button is greyed out?
Hello, everyone.
I am learning robotic machining on the ''learning advantage'', but I can't move on at this step. Because my ''import machine kit'' button is greyed out. I dont know the reason
I snipped my NX windows down below.
Thank you verymuch
Capture.PNGstep12.PNGstep23.PNGtutorial guide
Re: ''import machine kit'' button is greyed out?
Solved!
I just copy the whole MACH fold to a new file folder, and reset the environment variables to UGII_CAM_BASE_DIR=C:\Temp\MACH\.
Thanks very much for sharing the solution!
Never copy the entire MACH folder, you will find yourself in big trouble shortly.
The best practice is to only copy the "MACH\resource" folder and point the variable UGII_CAM_RESOURCE_DIR to it.
Please check if the related file in your environment is write protected. That will cause they greyed out status.
..MACH\resource\library\machine\ascii\machine_database.dat
Thomas
Thomas Schulz
Siemens PLM
I tried to just copy resource folder, but as a result I can't even start my manufacturing and machine tool builder application.
Have you also removed UGII_CAM_BASE_DIR pointing to the wrong location.
BTW, do not change files contained in the installation folder of NX, you will really get into trouble then.
If you need to create a customisable configuration use the NXcustom package, available through a search in this community, and follow the instructions included in that package to be successful.
Hi, I'm having the same problem. The machine_database.dat file isn't read-only.
I can use the "Machien Library" to create new entries or delete them.
Kleber Ronconi
Siemens PLM
Kleber Ronconi
Siemens PLM
