.ini file not registered
Morgen!
When I start my nc code file simulation I have a message :"INI-file was not registered"... I check all names, folders - I cannot find my fault.
What a reason?
Re: .ini file not registered
Moin! ;-)
with which NX Version do you work?
ThomasF
Machine Tool Enablement
NX 9.0.2.5, no problem, I can download latest release.
ok... please check the following points:
- which controller you want to simulate
If Sinumerik:
- is there another -Main.ini inside the subprog folder?
- whats the channel name inside the MCF?
- is there a second channel?
- is there a second "-" inside the machine name?
ThomasF
Thanks, Thomas!
Controller OKUMA...
2 CHANNELS, MacTurn
i tested a multichannel configuration with the sim05 OOTB Machine. In the attached screenshot you can see my working test setup. I named the channels CHAN1 and CHAN2
Thomas
Please give me feedback when it works
Of course, Thomas! I need some time to test it, now I out of office.
Thank you!
Thank you, Thomas!
It was my fault, I forget to check channels names and ini-files names.
You´re welcome! Thanks for your feedback!
