insert carrier with tools to new file automatically
Helo i created carrier with 90 tools and i want this carrier to be loaded to eny new file on nx10 cam
i attach file
thank youHeart
Amnon
7 REPLIES 7
Re: insert carrier with tools to new file automatically
Hi Amnon,
You can select all tools > MB3 > Object > Template Settings > and check the option Create if Parent is Created.
After you save the file you can configure this file as a template file.
Now, all new files you initialize with this template file will have all 90 tools you create.
I hope this help.
Jean Marcel
PLMPRO
www.plmpro.com.br
Hello Jean
thank you for your reply.
i tried to do what you offer, and i got partial solution.
when i create new file to nx10 cam i get all carriers, but not all the tools that i created in the original carrier.
I attach 2 files of origin file (mill_planer) and the new file (model1)
Thank you for your help
Amnon
Hi Amnon,
Please, select all nodes (Carrier, Pockets and Tools) and click MB3 > Object > Template Settings and check the option Create if Parent is Created.
Save file mill_planar.prt, close NX and reopen.
Now all (Carrier, Pockets and Tools) will be created in new file using mill_planar template.
Note, the Pockets 42-50 don't have tool, so, only pockets will be created.
I hope this help.
Jean Marcel
PLMPRO
www.plmpro.com.br
Hi Jean
thank you for your help.
i want something more:
create the same carrier with the same tools, but under a different name souch as "steel" and change speed and feed for steel.
how can i choose the carrier "steel" ?
thank you again
Amnon
Amnon,
Unfortunately, when you initialize a template, you can't choose what Carrier you would like to load.
The template will create the both carriers.
So, you can configure 3 different templates, for example:
First - mill_planar with 2 carriers (Carrier and Steel)
Second - mill_planar_carrier with only "Carrier"
Third - mill_planar_steel with only "Steel"
When you use a mill_planar template that have the "Carrier" and "Steel" you will need choose the right tool from the right carrier.
I hope this help.
Jean Marcel
PLMPRO
www.plmpro.com.br
I don't advise to do this because when you have to update it will be a mess.
Maybe you can bring in the tools as part of a machine CSE?
Dennis Rathi
Creations Unlimited
Thank you
