laser cutting
Folks,
Does NX CAM support laser cutting? post-processing, edit the cutting path, etc.
I mean laser cutting(triming) machine not laser head on the robotic arm.
Re: laser cutting
In theory, it can.
There was a thread a bit ago on how to turn laser on/off.
You could look at regular milling or wire EDM to create the toolpath
You'll have to figure out out to represent the laser beam as a cutting tool. (cylinder, or include some taper?)
You'll have to really modify a mill (or wire EDM) post.
Have fun!
