license as a plug
Hi
i have license "Siemens plm license server"
i don"t have maintenance support in Israel and i wonder how can i get a "plug" license from siemens.
i"m ready to pay for license.
thank"s
Amnon
I added license file, can you please tell me to which version does license fit?
Thank"s
Amnon
Re: license as a plug
In past I remember for SolidEdge was LPT-doungles, in my table i keep it. But - no for Unigraphics or NX.
I dont understand relations beetween protection type and technical support.....
And your license file for NX11, permanent license, but I see in INCREMENT line - you must have 2 workseats for UG Mfg Bundle, but in footer I see just 1...
Last note - I think, you never use your license file, in other case you must to change YourHostName to real hostname. Or - your server have a "YourHostName" name....
Ask Siemens for a SENL license with a Siemens supplied USB dongle.
The SENL license is a Standalone Node Locked License file which means you do not use the license service at all.
The license file will be coded with the dongle number.
The license variable SPLM_LICENSE_SERVER or the registry key for it, will be set to look directly at the license file, not for a license server.
Then when NX starts up, it will look for the license file and check that the dongle number in the license matches the number of the dongle that is plugged in.
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
Hi
thank you for your help.
can you please tell me how i ask siemens to supply me the dongle with my composite?
in Israel i don"t have maintenance, so i need siemens directly and i"ll pay for dongle.
can you give me link? or anything else?
regards,
Amnon
I work for a Siemens reseller in Australia so I know how to do that for our customers (under or off maintenance).
The situation in Israel is not known to me, but I would expect that you bought the license from someone, that is who you should be asking.
PhoenxPLM
Hi again
in israel i bought license from "Mckit" i don"t have maintenance with them, and they don"t want to sell me because of non maintenance.
this is why i want direct connection with siemens.
can i buy from Australia from you?
if not from you, from who?
We do this for non-maintenance customers with no trouble at all. I would suggest pushing them if they're the only Siemens reseller in Israel. I can't sell to you as we're only allowed to operate in Australia & New Zealand. Otherwise it looks like Israel falls under the European Siemens , try contacting them: https://www.plm.automation.siemens.com/en_us/about_us/contact/sales_emea.shtml
PhoenxPLM
Hi
you helped me a lot.
Amnon
