limit the spacing between goto points while ramping
Is there a way to limit the distance a tool moves while ramping. I have tried planar mill and z level profile.  Hole milling works and forces z with I,j,k but this shape is not round.  It’s a slot .075 wide and im using a .062 em.  Please look at the screen shot and you will see some of the distance moves between goto points are nearly .100.  it is cutting corners and gouging the part during entry.
Thanks, Damian
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
Re: limit the spacing between goto points while ramping
The engage moves of Ramp on Shape use the operation Intol/Outol. This picture shows the effect.
If you go to Cutting, Stock, Tolerances, and set Intol = 0.000 that should take care of it.
Mark Rief
Retired Siemens
That fixed it.  Thanks Mark!
Damian Forsythe
NX 10.0.3.5
