machine code simulation error
When open Simulate Machine in NX manufacture choose Machine code Simulate so NX appear warning such as in video.
Everyone have see this case, yet?
Re: machine code simulation error
Hi CoungVo,
I can´t watch the Video due to an error.
Try to add a screenshot or a description of this error including the NX Version.
Thomas
What says the log file? On which OS runs NX?
Hi Thomasfeind!
I create operation in NX 11 then take machine in library of NX, run "simulate machine" by "machine code simulate" but NX appear warning such as on.
Not so good idea simulate machine in GEOMETRY window - in PROGRAMM window will be more better. How you add your CNC?
Check machine_database.dat
Check .dat in CNC folder
Check *.pyc files in cse_driver folder
Thanks Chigishev!
I will check such as you guide.
