machine code simulation error
HI all,
when we try to simulate the programs we getting error,please find the attached screen shots.
Re: machine code simulation error
which NX Version have you started?
Are you using a local mach folder from another nx installation?
As the error message says, look into NX log file. What is in there regarding the Python error?
Thomas
am using NX 11.0.0.33. Am using MACH folder form the same NX installation.
Please find the attached NX log file.
hello
When you try to run the Post. Is it successful?
Post is successful but am trying to simulate the with the machine ,but getting error
I talked with some colleagues and we don´t understand this behavior. We tried the sim01 fanuc sample with the NX1101 standard installation and it works.
Our suggestion is that you open a call over GTAC that we can look into it.
alreadyopen IR in GTAC and they sujjest us to update from11.0.0 to 11.0.1.
Preetham
HI,
updated to NX11.0.1 now its working fine.
Preetham
Hi ,
Saw this error, we have the same error but in latest version of NX11.0.1.11 MP3.
Any suugestion? or do i need to IR since they suggested to just update the version but we already have the latest version.
Thankyou.
Just raise an IR so that GTAC team may give right solution .
