machining time
Hello
i'm having trouble with mom_machine_time   command, it shows 0 time for both hours and minutes for any operation i post process
this is my code
#display the estimated machining time
global mom_machine_time
set hours [format %2.0f [expr $mom_machine_time / 60]]
set minutes [format %2.0f [expr $mom_machine_time - 60 * $hours]]
MOM_output_literal "Estimated Machining Time: Hours:$hours Minutes:$minutes"
though it works if i replace mom_machine_time with mom_tool_path machining_time, any idea what i might be missing?
8 REPLIES 8
Re: machining time
where do you have this code/cmd in use?
also "global minutes hours " is missing
Re: machining time
Hi @Helmi
I have uploaded the postprocessor, that inside the post there is a time calcilation, Hour:MinuteSmiley Frustratedecond.
Please have a try for that:
https://community.plm.automation.siemens.com/siemensplm/attachments/siemensplm/open_forum/18807/1/ex...
Hope this will help you.
Maryadi
PT.MMT-Jakarta-Indonesia
Re: machining time
Hi @Helmi,
Create proc(custome command),In the end_of_path(PB) or start_of_operation, just insert this proc.
proc PB_CMD_TIME_est { } {
global mom_toolpath_time pathtime
global hour min sec
global hours minutes second
    if {$mom_toolpath_time >= "1" } {
       set hour [expr int(($mom_toolpath_time)/60)]
       set min [expr int($mom_toolpath_time-($hour*60))]
       set tot_min [expr int($mom_toolpath_time)]
       set sec [expr int(($mom_toolpath_time - $tot_min)*60)]
       set hours [format "%02d" $hour]
       set minutes [format "%02d" $min]
       set second [format "%02d" $sec]
       set pathtime "Time:$hours:$minutes:$second"
   } elseif {$mom_toolpath_time < "1"} {
       set second [format "%.0f" [expr $mom_toolpath_time*60 ]]
       set pathtime "Time:00:00:$second"
	MOM_output_literal "($pathtime)"
Maryadi
PT.MMT-Jakarta -Indonesia
Re: machining time
This is what I use to output time at end of program
Add this to Auto Tool Change
AddThis to End of Program
Re: machining time
Hello Maryadi
i created a procedure and pasted your TCL program, but when i post processed a part it doesn't output any time at all, just the usual G code
please keep in mind that i'm using Post Builder 9.0
Re: machining time
It is not enough to copy and past the proc, it is also necessary to call it...
e.g below :
proc myproc {} {
MOM_output_literal "myproc..."
# call proc to print info
myproc
# return
myproc...
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Re: machining time
Hello
i already created a Custom Command at the start of operation and it works fine and here it is
#display the machining time of the current operation
set hours [format %2.0f [expr $mom_toolpath_time / 60]]
set minutes [format %0.2s [expr $mom_toolpath_time - 60 * $hours]]
set s [expr $mom_toolpath_time - $minutes]
set seconds [format %2.0f [expr $s * 60]]
if { $hours > 0 } {
MOM_output_literal "temps estimé de l'opération: $hours heure(s), $minutes minute(s), $seconds seconde(s)"
} elseif {$minutes > 0 } {
MOM_output_literal "temps estimé de l'opération: $minutes minute(s), $seconds seconde(s)"
} else { MOM_output_literal "temps estimé de l'opération: $seconds seconde(s)" }
i want to know if i can sum the time of all the operations and display them at the end or start of program, if yes please then show me how
Re: machining time
It's not normal because Maryadi1 output at the end of proc "MOM_output_literal ($....)" If it does not work you should see anyway "N..... ()" or an error if the variable does not exist.
For end of program : Michael_Mannino 's solution
www.adgroupe.com
