Do you mean
Reply
Solved! Go to solution
milling center (tool center point), or cutting tip (point tool tip)
How to generate exit program using milling center (tool center point), or cutting tip (point tool tip) in NX 8?
see figure attached!
thank you!
Sorin Marcu
CNC Programmer
Matrite DACIA-Group Renault
Re: milling center (tool center point), or cutting tip (point tool tip)
please help me!!!
Sorin Marcu
CNC Programmer
I don't know what an "exit" program is, but you can use the offset to just adjust the posted code, or use tracking points to control it.
Jake Hardwick
CNC Programmer
Senior Aerospace AMT
Production NX8.5.3.3 Beta testing NX10.0.1.4
how can I do this in NX 8?
see picture!
thank you
Sorin Marcu
CNC Programmer
Solution
Solution
Accepted by topic author marcuisorin
‎08-26-2015 04:32 AM
You need to generate the surface contouring operaiton with "Output Contact Data" turned on.
Then (In NX9) when you post, there is an option to output ball center.
In prior releases, you need to modify the post to output ball center instead of tool tip. There is a custom command available for Post Builder.
Of course, it's more complicated than that, but this shoul dget you started.
Mark Rief
Retired Siemens
thank you very much
Sorin Marcu
CNC Programmer
