modify tracking selection in Operation CAM with C Open API
i need to know how i can modify/access the valu of <Defined Tracking Points> and <Main Tracking Point> by using C Open language.
There are some function for this? Any example?
Re: modify tracking selection in Operation CAM with C Open API
Standard response #1 :-)
Have you tried recording a journal?
Note you can use Preferences -> User interface to change the language to C++
yes, i tried, but in journal there isn't any reference or interaction for changing the data set.
   theSession->SetUndoMarkName(markId2, "Teach Mode - [AVV_4DD] Dialog");
    //   Dialog Begin Teach Mode - [AVV_4DD]
    NXOpen::UI *theUI = NXOpen::UI::GetUI();
    theUI->JournalPause();
ANSI C or managed C++, this makes a huge difference.
For ANSI C you should check the UF_CUTTER header files.
For managed C++ you would use the tacking point builder of the tool object.
The GTAC solution center offers some examples too.
sorry but i understand: i need to modify parameter in an operation not in cutter, in the UF_CUTTER header files i found only functions for modify the general trackin point of the cutters but not for simple operation (i need to modify Main Tracking Point with procedure)
Tracking points are inherited from the tool normally.
Attached find a VB.NET Journal to get the operation parameters of the currently selected operation, which might give you a hint about what kind of parameter is holding the requested information.
In the maintime ,thanks for help.
I made the same procedure to print all operation parameter in C, but i didn't find the value of "name parameter" immagine.pngI run the procedure modifing the Main Tracking Point value but i didn't see any significant difference for my case, so i think that i can't use parameters for my problem .
I agree that the tracking points are inherited from tool but in operation i need to set "Main Tracking Point" choosing from the available ones.
i don't tell you that i need to modify turning operation
Operation parameter 1060 are the tracking points inherited from the cutter.
Operation parameter 1061 are the tracking points available in the operation.
Have you tried changing operation parameter 1117.
I would do the following:
  1. run the journal and save the output to the file before_tp_change.txt
  2. change the tracking point
  3. re-run the journal and save the output to after_tp_change.txt
  4. compare both files with WinMerge, WinDiff or similar to find the difference
Have you also taken a look at the solution center examples?
Hi, i try what u say, but i don't obtain what i need. I also try to change parameter: 1132 and 1040,the significant differences in windiff, but when i reopen operation don' see difference.
Great tx for help!
no other idea?
