$mom_output_literal M=VNSRV[32] doesnt work
$mom_output_literal M=VNSRV[32] doesn't work in Post.  Can I get some ideas about syntax.  Can't seem to use a  \   to handle the []  as text.  This is NX 10.0.1.4 and PB 10.0.1.
4 REPLIES 4
Re: $mom_output_literal M=VNSRV[32] doesnt work
It works with PB 10.0.3
MOM_output_literal "M=VNSRV\[32\]"
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
Thanks.  That's what I tried.  Maybe just a glitch with 10.0.1 then?
Maybe.
You can try to use MOM_output_text instead MOM_output_literal - maybe it wil help
If you can't get latest QRMs, you can try to report it to GTAC.
and just to be sure:
- if you copied whole postprocessor folder from older NX to newer (instead copying only files of you postprocessors) - you can expect any kind of errors. I've seen people still doing this
Thanks.  That did it!
