new mom_operation_type values
I'm sure this is not a complete list, but it bugged me (and I needed to find out anyhow, for MY posts)
FLOOR_WALL_FLOOR - op type = "Volume Based 2.5D Milling" (floor/wall machining)
GROOVE_MILLING - op type = "Groove Milling"  (i.e. using a t cutter on the side of a part)
BOSS_MILLING - op type = "Cylinder Milling"
HOLE_MILLING - op type = "Cylinder Milling"
SPOT_DRILLING - op type = "Drilling"
DRILLING - op type = Drilling
DEEP_HOLE_DRILLING - op type = Drilling
COUNTERSINKING - op type = Drilling
TAPPING - op type = Drilling
SEQUENTIAL_DRILLING - op type = Drilling
HOLE_CHAMFER_MILLING - op type = "Chamfer Milling"
HOLE_THREAD_MILLING - op type = "Thread Milling"
BOSS_THREAD_MILLING - op type = Thread Milling
RADIAL_GROOVE_MILLING - op type = "Radial Groove Milling"
ROTARY_FLOOR - op type = "Variable-axis Surface Contouring"
If anyone knows of others, I'd appreciate your posting here.
ken
9 REPLIES 9
Re: new mom_operation_type values
Sorry - I haven't looked beyond my current version. But - why do we need to do specific things in the post based on the operation (especially something like make decisions about putting out blocks.) I guess I have had some need for it - but I would think it would be something to avoid - and would cause a lot of work in version change (like apparently now.) Maybe making kinematic switching automatic (I guess.) I have looked at "mom_tool_path_type" to see if "variable_axis" tool path and made decisions based on that. That variable came along in 8 or 8.5. Hard to keep up!
NX12.02
Windows 10 Pro
ITC Inc.
Just create any operation, just empty operation, any type, any subtype. In postprocessor insert to Event Operation Start PB_CMD with MOM_output_literal $mom_operation_type.
For MILL PART PROBING Mill Part Probing, for example...
NX9 :
wire_edm
operation name :NOCORE
oper_type :Wire EDM
operation name :EXTERNAL_TRIM
oper_type :Wire EDM
operation name :INTERNAL_TRIM
oper_type :Wire EDM
operation name :OPEN_PROFILE
oper_type :Wire EDM
probing
operation name :PROBING
oper_type :Mill Part Probing
operation name :MILL_PART_PROBING
operation name :TURN_PART_PROBING
oper_type :Turn Part Probing
operation name :MILL_TOOL_PROBING
oper_type :Mill Tool Probing
operation name :TURN_TOOL_PROBING
oper_type :Turn Tool Probing
operation name :GENERIC_MOTION
oper_type :Generic Motion
mill planar :
operation name :FLOOR_WALL
oper_type :Volume Based 2.5D Milling
operation name :FLOOR_WALL_IPW
operation name :FACE_MILLING_AREA
oper_type :Face Milling
operation name :FACE_MILLING_MANUAL
operation name :PLANAR_MILL
oper_type :Planar Milling
operation name :PLANAR_PROFILE
operation name :ROUGH_FOLLOW
operation name :ROUGH_ZIGZAG
operation name :CLEANUP_CORNERS
operation name :FINISH_WALLS
operation name :FINISH_FLOOR
operation name :GROOVE_MILLING
oper_type :Groove Milling
operation name :THREAD_MILLING
oper_type :Thread Milling
operation name :THREAD_MILLING_NX5
oper_type :Mill User-Defined
operation name :THREAD_MILLING_NX7
operation name :PLANAR_TEXT
oper_type :Planar Text
mill_multi_axis :
operation name :VARIABLE_CONTOUR
oper_type :Variable-axis Surface Contouring
operation name :VARIABLE_STREAMLINE
operation name :CONTOUR_PROFILE
operation name :ZLEVEL_5AXIS
oper_type :Variable-axis Z-Level Milling
operation name :SEQUENTIAL_MILL
oper_type :Sequential Mill Main Operation
operation name :VC_MULTI_DEPTH
operation name :VC_BOUNDARY_ZZ_LEAD_LAG
operation name :VC_SURF_AREA_ZZ_LEAD_LAG
operation name :ZIG_ZAG_SURFACE
oper_type :Zig-Zag Surface
mill_multi_blade :
operation name :MULTI_BLADE_ROUGH
operation name :HUB_FINISH
operation name :BLADE_FINISH
operation name :BLEND_FINISH
operation name :SPLITTER_FINISH
operation name :EDGE_FINISH
mill_contour :
operation name :CAVITY_MILL
oper_type :Cavity Milling
operation name :PLUNGE_MILLING
oper_type :Plunge Milling
operation name :CORNER_ROUGH
operation name :REST_MILLING
operation name :ZLEVEL_PROFILE
oper_type :Z-Level Milling
operation name :ZLEVEL_CORNER
operation name :FIXED_CONTOUR
oper_type :Fixed-axis Surface Contouring
operation name :CONTOUR_AREA
operation name :CONTOUR_SURFACE_AREA
operation name :STREAMLINE
operation name :CONTOUR_AREA_NON_STEEP
operation name :CONTOUR_AREA_DIR_STEEP
operation name :FLOWCUT_SINGLE
operation name :FLOWCUT_MULTIPLE
operation name :FLOWCUT_REF_TOOL
operation name :SOLID_PROFILE_3D
operation name :PROFILE_3D
operation name :CONTOUR_TEXT
operation name :ZLEVEL_FOLLOW_CAVITY
operation name :ZLEVEL_FOLLOW_CORE
operation name :ZLEVEL_PROFILE_STEEP
operation name :CONTOUR_ZIGZAG
operation name :CONTOUR_FOLLOW
operation name :FLOWCUT_SMOOTH
legacy_lathe :
operation name :LATHE-DRILL
oper_type :Lathe Drill
laser :
operation name :LASER_TEACH_MODE
oper_type :Laser TeachMode
hole_making :
operation name :SEQUENTIAL_DRILLING
oper_type :Drilling
operation name :BOSS_MILLING
oper_type :Cylinder Milling
operation name :BOSS_THREAD_MILLING
drill_op_type :
operation name :SPOT_FACING
oper_type :Point to Point
operation name :SPOT_DRILLING
operation name :DRILLING
operation name :PECK_DRILLING
operation name :BREAKCHIP_DRILLING
operation name :BORING
operation name :REAMING
operation name :COUNTERBORING
operation name :COUNTERSINKING
operation name :TAPPING
turning :
operation name :CENTERLINE_SPOTDRILL
oper_type :Turn Centerline Drilling
operation name :CENTERLINE_DRILLING
operation name :CENTERLINE_PECKDRILL
operation name :CENTERLINE_BREAKCHIP
operation name :CENTERLINE_REAMING
operation name :CENTERLINE_TAPPING
operation name :FACING
oper_type :Turn Roughing
operation name :ROUGH_TURN_OD
operation name :ROUGH_BACK_TURN
operation name :ROUGH_BORE_ID
operation name :ROUGH_BACK_BORE
operation name :FINISH_TURN_OD
oper_type :Turn Finishing
operation name :FINISH_BORE_ID
operation name :FINISH_BACK_BORE
operation name :TEACH_MODE
oper_type :Turn Teach Mode
operation name :GROOVE_OD
operation name :GROOVE_ID
operation name :GROOVE_FACE
operation name :THREAD_OD
oper_type :Turn Threading
operation name :THREAD_ID
operation name :PARTOFF
operation name :PARTOFF_NX85
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Why I use it:
To automatically set post behavior.
For instance in an integrex,
- if drill or "3+2" axis milling: Convert post to table-table; automatically output G68; use G43
- if variable axis/squential mill:: Convert post to head-table; don't output G68; use G43.4 )or G43.5? I forget)
For an XZC post
- if milling, automatically output G12/12.1/112 (and G13/13.1/113) and convert post to "polar" mod, at appropriate places if milling op, else leave as XZC (X=radius C=angle)
I see - that is nice. Similar to what I am talking about with prismatic vs variable axis. If you are working with 8.5 forward - take a look at "mom_tool_path_type" and I believe there are a couple other "operation class" type variables. Another option might be going to api for similar info (I need to learn to do that.) I suppose if the decision is left to a single routine (class of operations) it is not so bad from version to version to update that.
MKN - thanks, was that from a journal - maybe a collection exists to gather that info?
NX12.02
Windows 10 Pro
ITC Inc.
MKN - I forgot to thank you as well...
Although I just realized if I went thru all the operation template parts, that *should* cover all operation types ;-)
Inspired by the list for NX9 I've made this for NX10 and brought the result into a EXCEL-sheet. If anybody wants it, it's in the attachment.
Werner
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
To save other people time, in case they want to do this for themselves, I created a post to report:
- part name
- operation name
- operation type
- tool path type.
Output is a CSV with the above in that order (one line per operation)
- open part to test
- run post
- open CSV output in Excel (or spreadsheet of your choice)
See attached for ZIP
If you see any other output, let me know - I think I got rid of everything other than what I'm looking for.
Should be easy to add other variables if/as needed (assuming they are defined in "start of path")
Thanks Ken!
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
