no feed and speed when i import file to nx cam
Hi
i built carriers with tools and gave them feed and speed.(in Planner Mill)
whenn i load file to nx10 cam i don"t get feed and speed.
see the attached file.
 thank"s for help
Amnon
Re: no feed and speed when i import file to nx cam
Hi Amnon,
Unfotunately you can't assign feeds and speeds directly in the tool.
You can configure feeds and speeds in the operation.
To define feeds and speeds for diferent tools using some properties, like a part material, depth per cut, stepover, etc..., you need use Menu > Tools > Edit Machine Data Libraries.
Below a links with more information about.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:index_mfggeneral:xid384701:com_opts_...
http://community.plm.automation.siemens.com/t5/Discussion-Forum-NX/Edit-Machining-Data-Libraries/m-p...
I hope this help.
Jean Marcel
PLMPRO
www.plmpro.com.br
