nurb output Question
What is the nurb output in NX cam and How to use this ?
Thank you.
4 REPLIES 4
Re: nurb output Question
You get splines (aka nurbs) in your posted nc program instead of lines and arcs.
You need the following things:
  1. NX CAM nurbs license
  2. change the operation to output nurbs instead of arcs and lines
  3. configure the postprocessor to output nurbs
Hope this helps.
Thank you.
And where is the output nurb in operation ?
Thank
Machine Control => Motion Output Type here you can select what the most complex output is.
BTW, it is also better to have the output set to linear here instead of setting linear only in the postprocessor.
The setting in the postprocessor is too rough.
If you create a new post with a Siemens, Heidenhain, or Fanuc controller, then you should see a NURBS move event.
The custom command nurbs_initialize sets the mom_kin_nurbs_output_type (bspline, siemens_poly, heidenhain_poly).
Mark Rief
Retired Siemens
