nx10 post processor
Good day,
I am new user of NX10 Siemens... anybody can help me regarding post processor because before the file extension is "NC" but when i reset the server the file extension became "PTP"..
What should i do to go back the file extension to "NC" and the postprocessor "CF_master_Y-U_V6" "CF_master_YU_V6"......
Attached is the image i've taken. nc.jpgbefore
ptp.jpgafter i resetThanks,
arman
Re: nx10 post processor
set this extension in Postbuilder
The extension is determined by the post processor selected in the list. In your case, the list of postprocessors is different, and you have not selected the same post in the second picture, as it is not in the list.
If you are not using a machine tool in the setup, then you need to add your postprocessor to your template_post.dat file. If you are using a machine tool, the postprocessor list is part of the machine.
Sir MarkRief,
Have a nice day Sir... thank you for your idea on fixing this issue... Now the software is running back in normal like before.. God bless you and to your team.
Arman
good day,
Juraj thank you for sharing your ideas
arman
