nx11 menu changed in finish walls i dont find "on" can it be restored?
6 REPLIES 6
Re: nx11 menu changed in finish walls i dont find "on" can it be restored?
May I ask you to explain a bit more detailed what you see as an issue here?
Lead Product Manager - Mold & Die
When i need on in nx10 it is easy and fast, in nx11 it is slower especially in chain. I would expect siemens to add “on” in nx 11.
I can only guess you mean the pre selection of the tool position. You can do that either in the member list or with the newly added capability in NX January 2019.
Cheers,
Alexander
Thanks can I see demo?
Hi
i want "left right on" in tool side. in nx11 i dont see "tool position"
i believe it will come in january. but what i want is better and in one place.
thank you for help
It will work for Left/Right for Open Curves as well.
