output file
PLM World Member Pioneer PLM World Member Pioneer
When post processing a window pops up so you can browse for the file path. new version 12.02.09 loaded and now that area is gone. it happens on update loads however i forgot how to fix so it's back in the window. ANY HELP PLEASE!!
Re: output file
Reset your Configuration File.
Menu-->Preferences-->Manufacturing...
Configuration tab
Configuration File group-->Reset to Default button
Template Set group-->Reset to Default button
Select OK
