positioning tool via handles graphic lag
Does any one know of a way to stop graphics lagging when moving tool via handles for quick position tool length checklag.PNG
toolmaker, Senior CAM engineer
Re: positioning tool via handles graphic lag
This doesn't sound normal. How bad is the lag? Can you upload a short video to show the case?
i would but cant load video links are greyed out
Have you check the certifications page to make sure:
- you are on a supported computer
- you have a supported graphics card
- the graphics card driver is at (or later than) the certified driver version?
https://www.plm.automation.siemens.com/en_us/support/gtac/certifications.shtml
If all the above are true, does your system have a "built in" Intel graphics chip?  Perhaps NX is using that chip (vs. the graphics card) for some reason?
This looks like a problem that was fixed some time ago.
What release and MP are you running?
Is it native or Teamcenter?
Mark Rief
Retired Siemens
Mp has resolved this, thanks
