post process some special tools like T cutter and barrel cutter
I want to post process some special tools like T cutter and barrel cutter...i am not getting the output and the error shows up stating MOM_first_tool....error no 170002.
when i post a normal bull,ball and end mill it works absolutly fine...below is the post attached
please help
Re: post process some special tools like T cutter and barrel cutter
Problem is in your "custom_command_1":
MOM_output_literal "#501=[Format1 $mom_tool_corner1_radius]"
For T-cutter, you should use mom_tool_lower_corner_radius and mom_tool_upper_corner_radius
It is good idea to use [info exists ...] command when you are not sure if variable will be avaliable or not.
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
I would use a separate varaible to fillin the tool corner radius, like my_tool_corner_radius.
set my_tool_corner_radius 0.0
  if { [info exists mom_tool_corner1_radius] }  {
	set my_tool_corner_radius $mom_tool_corner1_radius
  if { [info exists mom_tool_lower_corner_radius] }  {
	set my_tool_corner_radius $mom_tool_lower_corner_radius
# and many more depending on the tool type ...
MOM_output_literal "#501=[Format1 $my_tool_corner_radius]"
