post processor for siemen 840d
Dear all
I am using NX 9. Now I create postproceesor for siemen 840d . I use library siemen840d . When I creat program planar and post why not output cycle800 . It output taori .
Thank you
Re: post processor for siemen 840d
I don't have any experience with that OTB template - but isn't there a ude available named "Sinumerik 840D" which has a dropdown called "Transformation" where you can set it to "Swiveling"? Try that - I think that is intended to be the way switch over.
NX10.03
Windows 7 Pro
Yes - be sure you are using the ude file that contains the Siemens cycles.
Take a look at mach\resource\user_def_event\Siemens_Cycles_plus_ude.cdl
Mark Rief
Retired Siemens
