02-03-2018 12:49 PM
02-06-2018 04:07 AM
Have you placed all your Components in the Machine Tool Builder under the Machine base (Root)?
02-19-2018 09:03 AM
In the case that is TPB simulaiton you may need to check if the tool is defined correctly, my the tool chaneg cause that problem. It also can be a problem of an old MTD driver using SIM_find_comp_by_name or SIM_mount_kim_comp.
