"Edit Machine Component"-window is not complete
Hello!
What's wrong if one user does not have this "List"-field? "Reset" does not affect.
Thank you all.
Werner
Werner
Production: NX10.0.3, FBM | TcUA 10.1.2.2
Development: VB.NET, Tcl/Tk | Testing: NX12.0
Re: "Edit Machine Component"-window is not complete
Maybe the collapsible group is closed and the setting is "Hide collapsed groups"
Try to change the setting doing a right mouse on the upper left corner of the dialog:
Thomas Schulz
Siemens PLM
I think you need to see the "More" state of the dialog.
Hit the little triangle at the very bottom of the dialog.
Mark Rief
Retired Siemens
