re-load Machining Data Libraries
How do I get NX to re-read the parameters from the file NX12\resource\library\feeds_speeds\ascii\machining_data.dat?  so far the only reliable method is to completely shut down NX and restart.  I remember there used to be a button that would refresh settings / template info?
Thanks Damian
Damian Forsythe
Impact Manufacturing Group
NX 10.0.3.5
Re: re-load Machining Data Libraries
Hi
Thomas
Thanks!
Damian Forsythe
NX 10.0.3.5
