roughing for impeller flute
hello, guys
Do we have a method can be used for roughing flute of impeller. (not use new NX mill mutiple blade module)
After I checked in 5 axis milling opertion there have a lot of operation are almost for finishing.
Do you have good input for this case?
UG3.0
UG6.0
NX10.0.35
NX11.0.1
UG_NX is my favorite !!!!!!
Re: roughing for impeller flute
Many years ago, before Multi-Blade, I use for this FIXED CONTOUR, CAVITY MILL.......
You could also use CONTOUR_AREA or VARIABLE_STREAMLINE with multiple passes along the Z-axis.
@Canateda wrote:
hello, guys
Thanks!
Is there a reason you don't want ot use the multi blade roughing operation? This is what it is for.
Mark Rief
Retired Siemens
The problem is, that this is an additional license, since it is a niche product and it is hard to get such a license for testing purposes.
Mark Rief
NX CAM Customer Success
It needs License.^_^
UG3.0
UG6.0
NX10.0.35
NX11.0.1
