sequential mill 3 axis
How to make the inner finish of the walls with the sequential mill 3 axis
With lateral steps
Re: sequential mill 3 axis
Hell Claudio
In your example part you need to change the stopping condition on the check surfaces between DS-CS and PS-CS tangency when you get to the fillet between the two floor faces. I attached a sample.
Hope this is what you are looking for. Glad to see somebody else still giving Sequential Milling some use. It is a very powerful way to machine.
Paul
But - why you change tool??!!
Seq Mill - my favorite method for toolpath generation...
I did it for your tool, no changes.
GOOD MORNING
HOW TO MAKE LOOP ON DS….
Descrição: GMP Marcatto
Salve em PDF,
salve uma árvore.
Claudio Souza
Processo
+55 (11) 4736-8900
claudio@gmpmarcatto.com.br
Descrição: GMP Marcatto gmpmarcatto.com.br
Descrição: GMP Marcatto /gmpmarcatto
Esta mensagem é para uso exclusivo de seu destinatário e pode conter
informações privilegiadas e confidenciais e não devem ser divulgadas a
terceiros sem o prévio consentimento por escrito da GMP Marcatto. Se você
não for o destinatário, não deve distribuir, copiar ou arquivar a mensagem.
Neste caso, por favor, notifique o remetente da mesma e destrua
imediatamente a mensagem. / This message is intended solely for the use of
its addressee and may contain privileged or confidential information and
shall not be disclosed to any third party without GMP Marcatto’s prior
written approval. If you are not the addressee you should not distribute,
copy or file this message. In this case, please notify the sender and
destroy its contents immediately.
PRT file.
Why use sequential mill for this path in 3x when you can use boundary a lot easier??
Dennis Rathi
Creations Unlimited
Path attached
Dennis Rathi
Creations Unlimited
Sometime Seq Mill more flexible. Of course, for this sample will be enough Fixed Contour or Planar Mill, but I have a lot of samples whrere Seq Mill is a last way to reach result. For example, I have some projects for SAPHIRE (!) milling&grinding, no any chance without Seq Mill, even for 3 axis operation. If I need to mill Rectangular web, and I need TURN ON cutter compensation just for one side only - I cannot to do it without Seq Mill..
SEQUENTIAL MILL - FOREVER! (I remeber this method from Unigraphics (not NX) version 10.5, no any changes. It is a sign - good method.)
