simulation output differs from the model
I'm working with 4 (A) axis machine and using NX 10. I am trying to do part which is shown in the pic. Part is basicly blade with one curved surface and I'm testing the machine with it.
The problem is that simulation output differs from the model. Here is pic what simulation gives. It looks like that blade is turning somehow during G-code simulation. Toolpath looks allright to me.
Verify tool path gives accurate output so is my problem in the post processor? I have also noted that every part is a little bit too small after G-code simulation but G-code it self is right and actual parts are correct sizes.
