Re: the poly programming
I am a customer, just to clarify Smiley Wink
If you use "Sinumerik Spline" as output, you should get the poly-line output you are seeking for.
If possible, it is best to attach a sample part file and the expected NC output file to the discussion, so others can change the settings to get the predicted result.
Re: the ploy programming
For Siemens Sinumerik you can use:
ASPLNE
BSPLINE
CSPLINE
ASPLINE and CSPLINE - little bit similar, through points. BSPLINE use inputs point like poles.
And you can use POLY interpolation, where
x=a1*x^3+a2*x^2+a3*x+xe, same for Y and Z (see programming manual).
But.
For BSPLINE you can get from NX full info about control points and weights for each points, NX will divide curved motion into spline segments with defined tolerance.
But I dont know any method to get poly coefficients for polinom.
For example, I have law-defined curve y=0.5*x^2 and toolpath on this curve.
spline.pngy=0.5*x*x
OOTB mill01_3ax postprocessor for linear motion output:
N320 ;Cutting
N330 X.174 Y.015
N340 X.347 Y.06
N350 X.521 Y.136
N360 X.694 Y.241
N370 X.868 Y.377
N380 X1.042 Y.543
N390 X1.25 Y.781
N400 X1.458 Y1.063
N410 X1.667 Y1.389
N420 X1.91 Y1.824
N430 X2.153 Y2.317
N440 X2.396 Y2.87
N450 X2.674 Y3.574
N460 X2.951 Y4.355
N470 X3.264 Y5.326
N480 X3.576 Y6.395
N490 X3.889 Y7.562
N500 X4.236 Y8.972
N510 X4.583 Y10.503
N520 X4.965 Y12.327
N530 X5. Y12.5
N540 ;Departure Move
N550 G0 Z10.
And with spline motion:
N320 ;Cutting
N330 X.174 Y.015
N340 BSPLINE SD=3 X.441 Y.059 PL=0.0
N350 X1.038 Y.443 PL=.057701
N360 X1.769 Y1.474 PL=.094265
N370 X2.705 Y3.482 PL=.120348
N380 X3.669 Y6.563 PL=.270964
N390 X4.437 Y9.767 PL=.308153
N400 X4.872 Y11.86 PL=.148569
N410 X5. Y12.5 PL=0.0
N420 ;Departure Move
N430 G0 Z10.
Of course, with POLY it can be like single motion, I no need polinom coefficient from CADCAM for this case, just from my head, but I dont know how get it from NX.....
ASPLNE
BSPLINE
CSPLINE
But.
N320 ;Cutting
N330 X.174 Y.015
N340 X.347 Y.06
N350 X.521 Y.136
N360 X.694 Y.241
N370 X.868 Y.377
N380 X1.042 Y.543
N390 X1.25 Y.781
N400 X1.458 Y1.063
N410 X1.667 Y1.389
N420 X1.91 Y1.824
N430 X2.153 Y2.317
N440 X2.396 Y2.87
N450 X2.674 Y3.574
N460 X2.951 Y4.355
N470 X3.264 Y5.326
N480 X3.576 Y6.395
N490 X3.889 Y7.562
N500 X4.236 Y8.972
N510 X4.583 Y10.503
N520 X4.965 Y12.327
N530 X5. Y12.5
N550 G0 Z10.
N320 ;Cutting
N330 X.174 Y.015
N430 G0 Z10.
For SIEMENS Sinumerik you can use different kind of splines:
ASPLINE
BSPLINE
CSPLINE
A- and C-SPLINE little bit similar, through points, BSPLINE use points as poles.
And you can use POLY where
x=a1*x^3+a2*x^2......
same for Y and Z
I have law-defined spline y=0.5*x*x,
And if you will use OOTB mill3ax postprocessor for BSPLINE will be:
N320 ;Cutting
N330 X.174 Y.015
N430 G0 Z10.
But - for POLY motion it will be one motion, one line for nc-programm. I dont know, how get poly coefficients from NX..
To get poly-line NC output you must fulfill the following prerequisites:
  1. own nurbs or sinumerik_spline NX license
    • nurb_output_enabler and sinumerik_spline are part of the 5-axis add-on license or any 5-axis machining license bundle
  2. change output in the operation to nurbs or sinumerik spline
  3. have a post-processor supporting nurbs or sinumerik splines
Without one of these you will not be able to get poly-line NC output.
