tool tilt not tilting
i am using tool tilt after my tool path is created but it is not undercutting.
i am driving from a point 5 inches above the part.
in tool tilt i set the angle to 180. degrees on every option but it is still not under cutting.
is there any other way to go about this?
3 REPLIES 3
Re: tool tilt not tilting
Does the original path undercut?
You need to start with a path that undercuts, since Tilt Tool Axis rotates the tool axis about the center of the ball end - it does not move the tool position.
Mark Rief
Retired Siemens
yes i changed the setting" check tool above ball" to off.
and created the tool path to cut to the surface, with collisions.
then once i got a tool path that under cut, i used the tool tilt to avoid the collisions.
thanks
@johnnyb Good to know you got it figured out :*)
Mark Rief
Retired Siemens
