variable Y axis
 I am wondering if you got any solution for this. This machine finish out for Y is offseted1.jpg2.jpg . Is there anyway of creating a MOM for if values of y is + the value is (+#102) while if the value if y is – it will be (-#102). Or do you have any work around apart from changing program.
Edwin
Re: variable Y axis
make the sign +/- a variable
and put custom command before each motion with condition you just said.
Re: variable Y axis
HI Juraj,
Thanks for your reply.Do you have guideline on how to create the variable?
Best Regards,
Edwin
Re: variable Y axis
hi,
in Y address:
type into this box a variable (example "sign")
$sign
put custom command in sections (before blocks) linear, circular, rapid move...etc..where your Y will be.
put into this custom command this:
global sign mom_pos
set sign "-#102]"
if {$mom_pos(1)>=0} {
set sign "+#102]"
Re: variable Y axis
Hi Juraj,
Thanks ...It works.
Best Regards,
Edwin
