variable spindle speed on turning
hello all.
while radial machining like the photo shown above i want to fixed my surface speed.
i assumed my spindle speed "S" for first pass and stepover is 1. My surface speed will be "pi*D*S" . then
in second pass , my spindle speed should be "pi*D*S/(pi*(D-1))"
third pass "pi*D*S/(pi*(D-2))"
and this should continue.
Is it possible to make this in the feeds and speeds diaolg box or should i figure it out in the PP?
Fatih
Re: variable spindle speed on turning
A lathe will support constant surface speed (G96), no need to change it manually.
@hjoy thank you for your quick reply. i got the G96 G97 and G92(G50) codes Smiley Happy
