Re: what is the best method for a slot machine on a taper surface
Sir,
This a sample part. I need to cut the similar part. The Z depth is around 75 mm and width is of 6 mm and the complete part is of sheet metal weld part. What I am facing problem is that a poor tool path results vibration during machining and tool breakage. So i ve mentioned a optimum /best tool path. Please suggest if you have one.
You have to uninstall Post Comandos, format hard disk, (format hard disk again), and reinstall everything and use Post Builder instead. The only way this slot will cut my friend!
On a more serious note, see below (again)
2. Cutting Parameters > Corner> Smoothing >
      Z-Axis Smoothing = ON
      And set ramp angle to 30deg
3. Turn on whatever compressor that comes with your controller and you are done
^ if you don't have a half decent compressor on the ctrl, use G2/G3 with a z motion. I bet you can write this 2x faster than it takes you to leave a post-it msg on the refrigerator for the wife to see.
kool down. I will try it.
Thank you, grateful for this. Wish you a wonderful day there
PS: How can you NOT be kool already if you use Post Builder (trade secret fella)
