what is the fan distance in tool tilt ?
Thank you .
3 REPLIES 3
Re: what is the fan distance in tool tilt ?
This controls how smoothly or abrubtly the tool axis changes from one aorintation to another.
It is explained with pictures in the help at CAM> Manufacturing General >Operation Navigator >Operation Navigator commands> Tool Path commands> Tilt Tool Axis
Mark Rief
Retired Siemens
Dear MarkRief
Thank you for your answer . But I can not open your picture.
Thank you .
@22 wrote:
Dear MarkRief
Thank you .
I did not post a picture - this is in the help so I showed the path that section.
If you do not install the help, you can read it directly online at https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:index
Follow the path, then select Tilt Tool Axis Dialog box.
Or... just search "Tilt Tool Axis Dialog box"
Mark Rief
Retired Siemens
