which operation is to cut inclined walls
11 REPLIES 11
Re: which operation is to cut inclined walls
How many axis 3, or more
Do you plan to use a tool with a matching angle?  Planar Mill
Or use a ball end mill to make multiple passes? - Fixed Contour
Or tilt the tool axis and cut with the side of the tool ?  Variable contour
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
3 axis
How to set these parameters?
The tool path cannot be generated.
The tool you have is a Ball Mill - you can't cut a non-planar surface with a Planan mill operation
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help/#goto:mfgmilling:fixed_and_var_contou...
Senior Aerospace
So there are no operations available in the mill planar that tool axis is in Z axis to machine the inclined wall
That is correct
Senior Aerospace
If you want to use Planar Mill, you have to be creative with setting your parameters.
Otherwise, another operation might be more suitable for this feature.
Salvador Peregrina
Manufacturing Team Leader| NX 12.0.2
Does your license give you the mill_contour template? If so, use the Zlevel Profile operation.
Only ,mill_planar
I apoligize, I should have tried this first
Here is a tool path using Planar mill on an inclined face.  This can be done in Planar mill, see attached file with NX11 .prt
Senior Aerospace
