3D Factory Layout for download
If you want to improve a Plant Simulation Model with nice 3D data and images, you can do this using jt files. Check the attached JT file that has been given to us by MAN.
Comments
PLM World Member Theorist PLM World Member Theorist
Does anyone have similar examples that they are allowed to share?
This is a beautiful factory layout, but I think It isn't made by FactoryCAD.
@dongshui8558 is right, the file is based on a 3D laser scan. The pointcloud has been analyzed to define objects and surfaces and optimized for further use.
Thanks for your reply, mh!
Best Regards
clj
Contributors
