cancel
API Script to Modify Laminate Failure Theory and Bond Shear Allowance
This API Script allows the modification of multiple user-selected Laminate Plate Properties Failure Theory and/or Bond Shear Allowable(s).   The script prompts for display of the Data Table with Laminate Plate Properties in the active Femap model and presents a dialog box with a list of Laminate Plate Properties for selection and modification of the Laminate Failure Theory and/or the value of the Bond Shear Allowable.
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
