API Scripts for Renaming Connection Regions and Connectors
Attached are 2 API scripts for renaming Connection Regions and Connectors:
1) Rename Connection Region by Solid and First Face ID.BAS:  This script sets the title of selected Connection Regions to the Solid 1 and the 1st Face ID in the list of surfaces.  e.g. Solid 2, Face ID: 395
2) Rename Connectors by Contact Region IDs.BAS:  This script set the title of the selected Connectors by the type of connection (Contact or Glued), Source Region Solid and Region ID, and Target Region Solid and ID.  e.g. Contact - Solid 8, Region 802 To Solid 7, Region 702
Cheers,
Chip Fricke
Best Regards,
Chip Fricke
Principal Applications Engineer - Femap Product Development
