Learning curve simulation
A Learning Curve is a graph that depicts the reduction in working time because of experience.
If you want to model a a learning curve within Plant Simulation you might use this model as a reference.
It reduces the worktime in a station over a time due to the learning effect.
.Models.Frame.Learning_progress
Method
:time
is
do
variable:=variable+1;
result:=time_to_num((20000*exp(-0.01*(variable)))+22000);
units:=result;
-- print result;
end;
Contributors
