Simcenter 3D API: Bolt
Siemens Enthusiast Siemens Enthusiast
Siemens Enthusiast
Utility Name
Bolt
Summary
Automatically create a beam link between 2 RBE2.
Detailed Description
Prerequisite: .fem ou .afm SAMCEF or NX NASTRAN with at least 1D beam collector, 1D RBE collector, and 3D pieces.
General Information
Compatible versions
Source code
Keywords
NX 10, NX 11
VB, DLL
Beam, RBE, link
Known Issues
None
Test Case
How to use the program:
In NX Open, open the associated fem file
  1. Launch the program
  2. Select the center of the first RBE2 and the associated surface (first hole)
  3. Select the center of the second RBE2 and the associated surface (second hole)
  4. Select the 1D RBE2 mesh collector, and the corresponding beam, to what need to be modeled (screw diameter)
  5. Select the beam orientation
  • The program will automatically create the link (beam + 2 RBE2)
Author
Name: Laurent Menanteau
@Laurent1
